Searush
Fancy PD on Saturday night? Hope to see you there.
That's my second invite, thanks. Kwacka pointed out it's the Raft race this weekend, but unfortunately I can't make either,
Hope you all have a cracking time.
Yes!. At home I can always use the bidet to spray the affected area with cold water - not possible on the boat - not got room for a bidet nor enough fresh water storage to run one even if I had the room. You try sitting in the cockpit with a "burning ring of fire" and concentrate on navigation matters, avoiding the mobo drivers (I con't class them as sailors) and other duties of the skipper. It is really difficult to concentrate on anything apart from the pain hence the need for instant relief.Umm...is that in any way related to sailing, or the dangers of the deep?
Reading the accounts of boats that get into trouble that are published in PBO it seems that often it is things happening together or shortly after each other that causes problems. Each of them is manageable on their own but together they can cause havoc. e.g. A rope goes round the propellor, fog descends, the wind dies, the radio stops working then someone falls overboard!
This is a very recognised feature in aviation - Crew Resource Management - where a series of small things lead to a disaster. Each 'small thing' contributing to the next small thing or distraction.
A lot of CRM is about avoiding overbearing Captains who intimidate crew into not speaking up.
I've always believed in speaking up when flying or sailing, better to look a live idiot...one time when a boy I said ' Dad, there's a submarine coming up behind us ! '
Dad was sure it was a wind-up and refused to look round; so was a bit surprised when an RN Oberon class boat went past on the surface at quite high speed.
Never be afraid to speak up !
threatening his manor or after his dolphin bitches.
Actually, quite a few folk could do with using this, though I would suggesting changing a few parameters.Dan, a very important question, deserving much thought and action.
I’m a member of the Cruising Yacht Association of Victoria. We encourage our members to look at this from a Risk Management point of view. Where (simplistically):
Risk = “Probability of something happening” (eg Rare . . . to Almost Certain) x “Consequences” (eg Trivial . . . to Catastrophic).
You then rank your list of risks and set out the equipment or actions to prevent/minimise, detect and recover from them. You might use this to make a Risk Plan and even incorporate the actions into your maintenance schedule (eg inspect stays every year AND before any major trip AND replace them every ten years).
Whilst each vessel will have a different Plan depending on the vessel, its crew, its sailing mode/area etc it does help to see other’s lists. Here is my ranked list of risks (any additions/subtractions?), (I forgot to include Sea Monsters), cheers Andrew:
Man Overboard
Flooding / Sinking
Anchoring system fails
Fire
Capsize
Lightning Strike
Dismasting
Crew injury
Crew illness
Collision
Motor not starting or running
Anchor drags
Grounding
Broaching or Pooping
Strong wind
Shore lines fail
Drinking Water depleted/spoiled
Food depleted/spoiled
Damaged Sails
Power failure/running low
(I should add that I mostly sail single handed, long distances, primarily up /down the East coast of Australia but one trip kept turning to port from Melbourne to Geraldton via Darwin)
Umm...gentlemen, I...I'm deeply reluctant to butt in here, but...raft races? Get-togethers this weekend? Curry sauce?
What happened to the nightmare of psychotic oversize porpoises, and submerged containers and mid-ocean dismastings?:dejection::grey:
Story book tales, just don't relate to the family cruising I do.
Well...not that I'd wish anything but safe and comfortable voyages on anyone, however mundane their sailing...but I'd think anything more ambitious than a row on the Serpentine includes potentially mortal risks - there was a fascinating but frightening thread here, maybe 18 months ago, about the potential for deadly peril when transferring by tender in winter.
That happened to me, in the Dover Strait separation zone, the heads door swung shut on me. No handle on the inside, sailing along by myself. I just booted the door open and laughed at the merest hint of adrenalin in my system.
The great Sir Robin Knox-Johnston took a 303 I believe, the Jungle Carbine would be ideal..
Most boat related deaths are in dinghies...
