tudorsailor
Can you not make your own O ring with this kit??A specialist O ring supplier should be able to help. I used these people last time I wanted a rare size. O Rings, Seals, Bearing, Mouldings - O Rings Limited
Possibly I think you'd need to make a lot of O-rings to justify buying that.Can you not make your own O ring with this kit??
I must have two of every O-ring on board. Mind you, the boat has been owned by a compulsive hoarder for the last 26 years!When you want an O ring you are usually far from a place that sells the correct size. I have used it to make small rings and it works for me. So yes it would be cheaper to buy the rings, but the convenience of having the right ring when you need is worth a lot.
