viago
im looking at buying grease for seacocks and general purpose use and wondered how there could be any difference between standard and marine grease. im a bit sceptical but remain willing to to be convinced.
If you have Blakes seacocks, use the Blakes branded grease. A small tub lasts a lifetime!
Itz like buying steel, if you buy normal stainless it looks like rust after a few months. If you buy 316 it looks like rust after a few years (if not cleaned)
Buy the marine grease or get out the chemistry books and study up
I prefer Keenol - lovely stuff and no adverse effects to date - works well in sea cocks, packed stern glands, bearings etc.thanks guys, marine it is. question is with zink, lithium, calcium, all three?
blakes seems to be the only one recommended thus far.
Blakes seacock, as the name implies, is only for seacocks. Bit expensive for other uses. But it is extremely sticky.
Yep - I have a "few" tins in stock - should keep me going for a "few" years.No longer available so if you have a good stock dont waste it.
The grease now sold in it's place is Ramonol White Grease ( a bit pricey though)
there is also a Ramonol Advanced Marine Grease ( even more expensive)
I have a tub of Castrol Water Pump grease which says it is lime based, which Vyv's link tells me is the same as calcium based. Would that be OK for winches? Maybe better than the blue stuff? It feels slipperier.
Also I saw some particularly expensive marine grease that said it was calcium phosphonate base whereas I think the norm is stearate isn't it? Is there some advantage?
I used Castrol Water Pump grease for years for my winches and the same stuff seems to be in my little Seawolf windlass gearbox. Good choice I would think. The Lewmar winch grease is completely different, seems to be silicone based, translucent, not a conventional grease at all.
I only know calcium phosphonate as a detergent additive in lubricating oils. No idea why it would be used in a grease. It is also used to prevent scaling in water systems, e.g. cooling towers, but that doesn't seem to be applicable here.
