sailorman
If my VSR goes kaput i have a change-over switch. in-built redundancyAS you posted I was editing this:
VSR's are "Betterer" EDIT: than normal Split Diodes.
The setup is alternator (80A) - Sterling booster - split diode - battery sensed. I never see much more than 13.5V going into the batteries. I suspect a steep voltage drop.
Would I get a better result with a VSR?
No, there's a fault somewhere. Possibly the Sterling regulator isn't working properly.
I was hoping to find clarification of what to me is a black art, but so far I have only got more confusion.
My service batteries (2x155Ah semi deep cycle) never seem to get a good charge from the alternator.
When on mains, the Mastervolt charger puts 14.4 volts into the batteries, so there the split diodes do not seem to have a detrimental effect.
I do not know the exact types, will check tomorrowBut is the Mastervolt charger one with just a single a output and using the same diode splitter as alternator and Sterling controller. Or is it in fact a dual output charger which supplies the battery banks directly. As far as i know only the smallest Mastervolt (10amps) has just a single output.
A larger one ( at least 25amps) would be recommended for the battery capacity you have and all the larger ones have 2 or 3 outputs.
Check on the Mastervolt installation first, just to be sure about it, but then check the Sterling controller installation in particular that the sensing is connected correctly.
Which Sterling unit do you have ?
. I've got various battery switches and a spare splitter diode which came with the boat. I am not sure why I bother to carry it around as the current set up (pardon the pun) has worked faultlessly for the last ten years. I had the same system on our previous boat which also worked faultlessly. But I am the first to admit such statements prove nothing.If my VSR goes kaput i have a change-over switch. in-built redundancy
This highlights major problems with these kind of forums. It needs a book to properly answer most questions posted here, so you are not going to get a full answer which can relate to your installation on your boat. I'm afraid the "confusion" is added by people posting their opinions and often ignoring the facts. Electrickery is basically very logical - Ohms Law is very simple. When the voltage goes down the current goes down if the resistance in the circuit stays the same. If the resistance, or corrosion, goes up and the voltage stays the same then the current in the circuit goes down. The voltage at the batteries can therefore be very different from the voltage at the charge source output because of "resistance" in the circuit. There can be a dozen or more connections, bus bars, or joints, in the positive and negative cables supplying a load. Each can cause a small voltage drop with old corroded connections. A small 0.1v drop on a cable carrying a small current can become 5.0v when carrying a large current. This is where it comes a "Black Art" understanding a fixing problems.I was hoping to find clarification of what to me is a black art, but so far I have only got more confusion.
If the voltage sense wire is on the starter battery that will not produce the right voltage at the service battery.I never see much more than 13.5V going into the batteries. I suspect a steep voltage drop.
Normal/old Split Diodes have a volt drop of 0.7 volts or more. This is what causes the problems.I don't know what you mean by 'normal split diodes'.
I'm not sure many people will understand what you are saying here. It's difficult to wire them incorrectly....The only point I want people to understand is that they shouldn't be suckered into condemning split charge systems using diodes just because some of them aren't wired very sensibly.
I would suggest that 25 Amps is not a "large one".....As far as i know only the smallest Mastervolt (10amps) has just a single output.
A larger one ( at least 25amps) would be recommended for the battery capacity you have and all the larger ones have 2 or 3 outputs....
Most FLA batteries need to be charged with a current that is the Battery Capacity/5 - always follow the battery manufacturers recommendations. So the OP's 310Ah bank may need to be charged at 62 amps. So to be able to supply boat loads as well then the charger/alternator needs to be about C/5, which would be 70-75 Amps, not 25 Amps.
So if I have 480 amp/hr battery bank at 24v what size charger do I need? your calculation suggests 96 amp at 24v. I only have a 15amp/hr at 24v mains battery charger for use in the winter whilst we are on shore power. The main engine alternator is only 60 amp output at 24v but we do have 320w of solar and a Duogen. if I don't put a bigger mains charger on there am I really at a disadvantage?
I have a VSR from the alternator to three outputs - house - starter - bowthruster. Can I connect the shore power charger to the alternator stud on the VSR so it also sends its charge off those three ways?
.... if I don't put a bigger mains charger on there am I really at a disadvantage? If I ran my engine, generator and duogen in towed mode I could probably muster 85 amps output at 24v in an emergency but I would have to be underway
No, you're not at a disadvantage. Smaller chargers work fine, they just take longer.
The problem is you can't monitor both batteries, and they may both be at different voltages. You should monitor the service battery.What I thought I had made clear was that incorrect wiring is 'without voltage sensing at the battery terminal' in this context.
I agree. The simplest solution is a Battery Monitor with alarms. My BEP alarms can be set for High/Low voltage for three batteries and low Ahs. An external alarm can be fed to the cockpit.Even with a VSR you ought to have an over voltage protection circuit as part of your 'smart' alternator regulator. Its all too easy to motor along with a fault while cooking the batteries....
