andy_wilson
Pre-heaters.
I'm not sure about the validity in significantly tackling wear. Probably more use in speeding the warm-up cycle, and preventing condensation in engines with a very short runing cycle.
Marine engines suffer from long periods of idleness between duty. This leads to significant drain down of oil from the relevant bearings and surfaces.
Pre-heating might be handy in extremely cold service conditions, but would have such a minor impact in improved oil flow from a cold start after say 6 weeks standing.
Far better I would venture to find the decompressors - if fitted - and turn over without load until good oil pressure is acheived, then start the engine. I realise that they don't figure in larger modern engines.
Biggest risk area incidentally is cylinder bore wear, which repeatedly shows up in marine engine oil analysis as excessive Iron and Chromium (bores and rings).
