What's a check stay ?
Boo2
13 Jan 2010
Sorry for the very obvious question but I've come across a boat advert which mentions "check stays" and google didn't seem to help much. Are they like running backstays, or like baby forestays, or what ?
Thanks,
Boo2
They're running backstays
Don't know why they're also called check stays, except that the can be used to "check" mast bend, outside of stopping the mast from pumping..
Yes, I already saw that, but what are they ? Are they baby stays (in front of the mast) or runners (behind the mast) ? Or what ?
Thanks,
Boo2
They are behind the mast, like backstays. Typically only on a fractional rig.
They can have two purposes.
In light air, ease the backstay a bit (lets top of mast forward) and pull on a bit of checkstay (pulls center of mast aft) to straighten the mast (not invert it, just get it more nearly straight and take out some of the bend). This makes the main fuller and more powerful.
In heavy air and waves, with the backstay cranked fully on (to flatten / depower the main), the middle part of the mast might pump forward and back. If so, a little bit of checkstay tension (not enough to straighten the mast) can stabilise it and stop it pumping.
Not very common these days, AFAIK. Typically only necessary or useful on a very bendy mast.
