lw395
No, I'm suggesting it's good to remove the exhaust hose, so there is no source of water vapour going straight up the manifold.I understand in minute detail exactly not only what an engine exhaust looks like but how it works.
Are you actually suggesting that we should remove the wet exhaust hosing, remove the injection elbow and then either remove the manifold or spray it internally with anti-corrosion spray if it's not removable, if the engine is not going to be run for several weeks?
Is this a wind-up?
Richard
If you like, spray some oil, wd40 whatever up the elbow.
I thought this was standard practice, it's what everyone I know used to do before the interweb started blathering on about antifreeze in the seawater system.
Alternatively, be sure to run the engine at least once a fortnight.
