Gordonmc
I had a similar bad experience with Deks Olje many years ago, after using many layers of the base coat to soak in and then the top coat, but was applying it to a mahogany type hard wood. Went over to woodstain and this is widely used in Orkney and Shetland.
However, to be fair to Deks Olje wooden boats in Norway tend to be built of larch or similar and I have seen many nice oiled hulls over there so its perhaps a case of it only working well on the type of wood it was developed for.
I tend to agree that there is no such thing as a perfect cover for all woods. After seeing some oiled boats from Norway on the Banff - Stavanger race I did the exterior mahogany brightwork with Deks, both No 1 and 2 with the recommended number of coats. It lasted barely a year. Since going to Le Tonkenois I haven't looked back. I normally buy from a UK distributor from his boat-jumble stall to save postage costs.
Coelan has its enthusiasts, but again much depends on the wood its used on. An acquaintance had to strip the coelan off his newly bought teak boat as water had got under the surface and the stuff was coming off in sheets. It is possible the prep. was not as rigorous as required; ie. strip to bare wood, de-oil with acetone, one coat of Coelan primer and then multiple coats of Coelan, all on the same day. That regime is far from practical.
