BartW
The old steering system from the boat is completely hydraulic,
Hydraulic hoses go from the 2 steering wheels to the hydraulic pump in the engine room,
And from there, hydraulic hoses go to the rudder cylinders.
I never investigated this thoroughly..
Last Monday we discovered a squeaking noise from the electric motor that is driving the hydraulic pump,
but the motor is still running, and the pump is still working.
I assume a bearing from the electric motor is damaged from corrosion,
There are traces from water ingress on the electric motor,
water came in through the temporarely sealing of the deckfloor during the engine rebuilt.
within one week I want to do the sea trial with the rebuild engine,
But I’m not sure if I can have that bearing repaired in one week time,
I think that I can turn the wheel / move the rudders without running the hydraulic pump
But need to do more force and much more turning on the steering wheel,
Can someone tell me if I can do this, or can I damage something ?
Or is the weel unuseable without the hydraulic pump running?
I can switch "on" the pump, but am afraid that this will cause more damage on the squeaking electric motor.
thanks for advice !
thanks for advice !
