Boo2
I have heard KY jelly is a good water based lubricant![]()
Does being water-based mean it's not suitable for use in your stern tube ?
Boo2
Boo2
Boo2
It works OK, but there are special lubes for this purpose.Does [KY] being water-based mean it's not suitable for use in your stern tube ?![]()
I imagine that any lubricaant isn't going to stay on it long.
Just use washing up liquid to help insert the impeller and don't be too bothered as to which way round the vanes lie. As soon as the impeller turns they will lie in the right way, and they are then lubricated by water. Which is what is intended.
"....Normally the impeller rubs against a static brass cover plate with sea water as lubricant, hence a rapid failure when running dry. The illustration shows the Award Winning Extra Slip Bearing used by Speedseal Life with a PTFE disc placed between the end of the cover recess and the rotating brass disc which is in contact with the impeller...."
So what happens to other end?I understand from the SpeedSeal website that when destructive overheating and breakup occurs - due to dry running without cooling/lubricant - the significant damage is to the END which bears on the cover plate. That's why, apparently, the latest SpeedSealLife device incorporates a PTFE disc inside the cover plate.
So why did the impeller I removed last month have a vane pointing the wrong way?don't be too bothered as to which way round the vanes lie. As soon as the impellor turns they will lie in the right way...
Exactly!
I changed mine last month, for the first time since I bought the boat in 2010. One vane pointing "wrong way" on the old one being removed so I thought that was incorrect, but when I tried to place-in the new impeller with all vanes facing same way one of them "flipped" back to "wrong" way. So I accepted the seemingly incorrect installation and replaced the cover plate, feeling quite chuffed with myself for having done a long-put-off problem job.
Now I find that I should or should not have used some sort of lubricant.
The engine runs fine, plenty of cooling water coming out the exhaust, bingo!
But now I shall be WORRYING all the time that I have an impeller running-dry and about to break-up.
So much for "care-free" yachting..............
Did I do it the correct way - OR NOT?
I use a cable-tie or Jubilee clip to semi-compress the blades.when I tried to place-in the new impeller with all vanes facing same way one of them "flipped" back to "wrong" way...
