DeeGee
I doubt it - if you are correct then you are saying that there is a 100% discrepancy in efficiency between one engine and another. Not very probable, for modern engines! My figure is from the Yanmar 110hp motor which is turbocharged so might be a bit more efficient than yours, but not a huge amount.
Let's be clear, we are talking about the fuel actually burnt at a given power output and the output is shaft output from the engine/gearbox, not delivered by the prop. I can't follow your arithmetic. What is 0.88T ? To get the figure I gave to litres per hour you need to convert mass (grammes) to volume (litres) so you need the specific gravity of diesel at ambient. The other factor is 'horsepower-hours' which is the actual horsepower being used, not the rated hp of the engine, of course. Does that help?
edit:- ps if your calculation suggests double the fuel actually used then could it be that you normally run at 50% of rated output and you have used the rated figure of 28 when calculating horspower-hours?
0.88 Tonnes/cu.metre -- still say this is a totally useless formula - how the hell is anyone supposed to know what developed hp they are running at, at any particular time, or on average??
