What small electrical connector do I need ?
The one you have pictured is like mine. I seem to remember that the tab under the fuse is something to do with the load it can give without going via the battery. The wires from the solar panel and to the battery are just in screwed down clamps in the green bar. The temperature compensator is build in to the unit so ideally the unit needs to be near the batterys.
That’s the victron direct socket, Used for the comms to cerbo or pc
use the small Bluetooth temp sensor, makes it very easy
ah thx all, don’t need a temp sensor at all as the unit will be fixed in the same compartment as the batteries
tnx for the connector link, I don’t want to interfac with it further so will give that a miss !
