A
Anonymous
What I asked you is whether, in your opinion, a 24V windlass connected to a 12V supply would either draw a high current or a low current. The correct answer is that it will draw a low current and barely work. You don't need to introduce 18V or falling voltages or any other complications. It's just a variant of a series-wound dc motor. All motors start off 'stalled'. Series wound motors have a very high starting torque at the expense of a high starting current. For a given supply voltage, the current is load dependant. But, if the supply volts fall, so the current and power fall.
By the way, since these windlasses can run unloaded, the motors cannot be straightforward series wound or they would over speed and destroy themselves; it might be a compound winding but the characteristic will be essentially series to get the high torque required at low speeds. I presume, but I couldn't be 100% sure, there is more than one way to skin a cat - even a Ship's Cat /forums/images/graemlins/smile.gif They could be compound or even shunt wound with suitable gearing. I am going to take my Tigress apart shortly and might find out.
The outcome of that belief (which is what I accept and is what happens in my experience because the breaker opens when the motor is slowed or stalled through overload) is that the motor draws more current when the voltage is reduced.
The reason the breaker opens when the motor is slowed or stalled is because the load has increased, thus increasing the current. The supply voltage is always assumed to be, for all practical purposes, fixed, at 12V. If the supply volts fall, then so will the current.
It isn't going to be easy for you to prove it to yourself unless you have a high-power variable supply but I assure you that if you connect up a variable supply to a windlass you will find the current falls as the volts fall. I had hoped that since you seem to have access to lots of kit you might have easily been able to connect a 24V windlass to a 12V supply and see for yourself. It won't take more than half and hour. Don't worry, it won't damage anything, I promise you /forums/images/graemlins/smile.gif
