What size nut is this?
Kelpie
15 May 2005
Afloat
I need to source a replacement for a nut. It looks very close to a 28mm standard plumbing part, but is a little smaller.
I'm guessing that it might be some sort of imperial size. Would 1" BSP sound right?
The diameter of the threads, inside the nut, is about 33mm.
Would post a photo if I wasn't a bit of a luddite...
chewi
8 Oct 2007
Poole
I think you need to check your dimensions.
33mm dia is avery long way from 28mm and even further from 25.4 mm (inch)
theoldsalt
24 Nov 2010
Bristol
Possibly - see here http://www.tapshop.net/bsp_etc/
superheat6k
10 Jan 2012
South Coast
1 inch BSP refers to the internal diameter of the intended pipe the nut secures, so the OP is correct the ID and OD will be larger, but 1" BSP has a minor diameter of 30.3mm 33mm would be very sloppy.
So OP do you know the OD and preferably the pitch. To work this out count how many peaks occur is say 1/2" of thread and double it, or how many in say 10mm and divide it to get the pitch.
Kelpie
15 May 2005
Afloat
At the moment I only have access to the (cracked) nut, not the pipe itself.
I've tried screwing it onto a 28mm fitting and it will go a couple of turns, but clearly is not the right size/thread.
PuffTheMagicDragon
It sounds like a 1" BSP. This has 11TPI while a 7/8" BSP (your 28mm?) would have 14TPI. This would explain why the nut will only mate for two turns but will go no further.
Kelpie
15 May 2005
Afloat
Hmm, counting threads is tricky. Doing it very roughly using a rubbish set of calipers, I get about 16tpi. If I'm measuring it right...
EDIT- using the same method, I get about 15tpi on my 28mm fitting.
The mystery nut is definately a finer pitch.
Lakesailor
15 Feb 2005
Near Here
I have a thread file for cleaning up the threads. Each of the 8 faces is marked with TPI. That makes matching up easier.
Try pressing some putty or similar into the threads in the nut and then measuring that.
Kelpie
15 May 2005
Afloat
Well, fortunately (?) the nut has actually split in two, so measuring the threads is easier than it would otherwise be. It was held together with tape which is how I was able to try it on a 28mm fitting and conclude that it wasn't a match.
Davegriff
19 Jun 2010
SoF
A good start would be to determine whether the nut is metric or imperial. If its original, it'll likely be the same as the rest of the boat, so age of boat or country of origin would be a clue.
Kelpie
15 May 2005
Afloat
It's an American designed, British built, boat from 1970. So would that point towards imperial?
I was just asking the question in the hope that there would only be a small number of possible answers, but it doesn't look that way....
Lakesailor
15 Feb 2005
Near Here
Why not take the nut to a fixings company and ask them for an answer. We have a situation here of the short-sighted leading the blind and all will be guesswork.
If there are no fixing companies close-to-hand, you'll have to travel!!
Apart from a decorating shop and a quarry I expect his options are limited.
VicS
13 Jul 2002
If you measure the OD of the thread ( I take it 33mm is the core diameter/ ID of the nut) and the pitch in tpi or in mm it should be able to identify the thread from the tables available
Vernier, thread gauge and "Zeus" !
