lw395
As a modest 'aside', the Harbourmaster at Fowey - who is responsible for the several hundred moorings there - pointed out the problematic practice of yotties winding a nut onto an anchor or mooring shackle as tight as a big wrench can get it. "Some even use a long extension bar," he said. "That adds nothing whatever to the strength of the fitting. In fact, it weakens it, for over-tightening scrapes off the galvanizing microscopically where the male ( pin ) thread and the female ( nut ) thread interlock. Corrosion starts there immediately, and spreads progressively under the adjacent galvanising. That can half the expected service life of a good mooring shackle. So," he advised, " do a nut up firmly, no more, then lock it with wire or cable ties. Inspect it at least twice a year."
FWIW....
Sounds like drivel to me.
More corrosion happens through stuff moving and wearing off the oxide layer.
Two galvanised surfaces will actually weld together. galvanising works like an anode, so is not prone to corrosion getting under it like say chrome plating.
Anything locked with wire is prone to cretin sailing schools lassoing the buoy and pulling the wire off.
A cable tie has limited strength.
If you are going to mouse shackles and rely on it, use something pretty stout. The thickest plastic coated garden wire is quite good.
