demonboy
The large portlight in my cabin had been leaking very slightly so I unscrewed the frame from the deck and filled in various cracks and holes with epoxy. I then refitted the frame by Sikaflexing it back into place. Now the leaks are even worse!
When I took the frame off I noticed that it had never been Sikaflexed in the first place. It appeared to have a very thin layer of some putty type material and I got the impression the putty was designed to never fully dry, but that might have been the leak always making it wet. The boat is 20 years old.
What should I be using when refitting the frame? There's a slight chance I didn't use enough Sikaflex as I only have a small amount (you can't buy it in India) but since the stuff spreads out when the frame is put in place, I'm surprised the leak is worse.
Any tips/tricks, bearing in mind I'm in a country that doesn't have marine materials to hand?
