Ian MacAulay
for some time now I been battling to find the cause of my over heat alarms going off.
temp gauges all seam fine but alarms keep going off. it started at 3000rpm + but now is going off at 2000rpm so getting worse... I took a look at where it gets its tempter feed from and it appears that the temp sender coming from the water temperature on the top of the engine only feeds the gauge. Is there a second temp sender is so where and what's it measuring oil or water?
Need to get to the bottom of this as now defiantly thinking I may really have a overheat issue. They are twin ad41 lumps
thanks
Ian
thanks
Ian
