What sealant
Graham_Wright
30 Dec 2002
Gloucestershire
www.mastaclimba.com
What is the consensus on sealants. I used to be a fan of Sikaflex but it has failed in my resealed windows.
Usage underwater sounds risky.
What is the best choice under rubbing strakes?
Thanks in anticipation.
<hr width=100% size=1>GBW
danielbroad
17 Sep 2003
The "Dow Corning Marine Sealant" with 10 year guarantee that you find in chandlers is the best i've used - its silicon though so only use above the waterline.
AndrewB
7 Jun 2001
Dover/Corfu
Failure of Sikaflex.
This is a surprise, as I've found it extremely reliable, including on window-frames and underwater. Two suggestions though:
- It goes off and for best results must be used within a limited time, about 6 months from purchase and within two or three weeks of first opening, even though it is workable for longer.
- There are various grades of Sikaflex. The commonest, Sikaflex-291 is not UV proof and is not recommended for bedding windows, particularly the frameless type. Sikaflex-295/UV should be used.
An alternative is 3M Marine Adhesive Sealant, also a range of grades, polyurethane based like Sikaflex. The non-adhesive silicon sealants like Dow Corning are also effective, but less reliable in critical applications.
DepSol
6 Oct 2001
Guernsey
Re: Failure of Sikaflex.
The 3M UV 400 is the best there is and wont go yellow either.
<hr width=100% size=1>Dom
<A target="_blank" HREF=http://www.soltron.co.uk>the website</A>
BigLes
14 Jul 2001
Chichester
I've recently had the same problem - bonded the Acrylic windows directly to the GRP coach roof, and now after about 6 weeks they are leaking. Having investigated I have found the bonding has detached from the Acrylic and now realise I used the wrong sealant (SikaFlex 292), I should also have prepared the Acrylic before bonding. I should have used SikaFlex 295UV, abraded the Acrylic and painted Primer 290 directly on to the Acrylic. Once dried then bond the windows.
See: www.sikaindustry.com/ind/ipd-marine.htm
Needless to say I will be trying this once I have removed the offending windows again!
alec
16 Sep 2003
East Coast
I have had excellent results from the following :-
Life Caulk - Skin fittings etc. Cures by moisture and designed for
underwater use.
Life Seal - Designed for bedding in windows. Nice shiny finish and good
UV resistance.
Even when I have used 'marine' type silicones results have been poor. Possibly due to seawater contact and UV.
REgards,
