What reefs should I put in for 250mph gusts?
A former colleague worked on tankers. He said he'd seen welded deck fitting come off in those sorts of conditions. You won't need to worry about shortening your mast; the wind will take care of that for you.
On rolling, Hammond Innes had his steel boat built in Holland (as one does..) then motored across to UK to have it fitted out and rigged. He said the rolling was extremely uncomfortable. No underwear was mentioned.
I believe the Mt, Washington recorded wind speed was when the gear was blown off the mast, the actual wind was higher.
I think they are not so much poking fun at the Anderson 22 per se, but at the memory of one of its former champions on this forum.
It is related to a former forumite, Seajet, who was a valued and informative participant of the forum, who I for one miss on here, but who did take his enthusiasm for Anderson 22s (and some of his other views) to extremes at times. I think most on here would accept the Anderson 22 is a very good boat of its type, but Seajet couldn't accept that others might have different views, preferences or needs, and occasionally made implausible (and unnecessary) claims for its capabilities and performance.
"If Carlsberg - or Thunderbirds - had built a sailboat, it would have been an Anderson 22...."
I know the celebrated Seajet well. He doesn't suffer fools gladly - or at all.
Launched my mashford four tonner…..had to wait a tide before stepping the mast,nearly fell off several times,extrodinary how much stability a mast weight adds
