Richard10002
Having fixed the autohelm linear drive unit, and the rudder reference transducer, I thought I had cracked it… but no… God has it in for me.
The steering system is Whitlock Constellation pedestal where the wheel turns a cogged wheel with a chain on it. The ends of the chain are connected to wires inside the pedestal, then the wires exit the pedestal through the cockpit floor into the engine room. At the cockpit floor, the wires enter a stiff tubing, (bit like a bicycle brake system), which continues all the way to the steering quadrant under the aft bunk.
At the quadrant the wires leave the tubing and proceed around the quadrant. One of the wires passes around a pulley type wheel to change its’ direction… so one wire pulls the quadrant one way, and the other wire pulls it the other way.
The autopilot linear drive unit arm is connected to a tiller arm which is fixed to the rudder stock under the quadrant,
Having fitted the drive and reference transducer, I tested the steering with the autopilot on standby. Everything fine…wheel spins freely, rudder quadrant turns freely, linear drive moves in and out freely, rudder reference shows correct readings.
Turn the autopilot to auto, and add 10 degrees… nothing moves. Try minus 10 degrees… nothing moves.
Test linear drive with independent 12 volt supply and, whilst it tries to, it cant move the rudder, and nor can I … the drive moves fine when disconnected from the rudder.
Disconnected the wires from the quadrant, rudder moves freely, both by hand and by powering the linear drive.
At all times, hand steering at the wheel works fine.
So… something is stopping the steering gear wires from being pulled from the quadrant end, at the same time allowing them to be pulled from the wheel end.
Any ideas?
Many Thanks
Richard
Any ideas?
Many Thanks
Richard
