What makes the best electrical join?
What is the optimal method for joining untinned copper wires on a boat?
  • Chocolate box connector - untreated copper ends to wires
    Votes: 4 3.2%
  • Tin the ends, then use a chocolate box connector
    Votes: 2 1.6%
  • Crimp connectors - untreated copper ends
    Votes: 21 16.7%
  • Crimp connectors - tinned ends
    Votes: 12 9.5%
  • Waterproof junction box
    Votes: 3 2.4%
  • Soldered joints protected by heat shrink
    Votes: 77 61.1%
  • Chocolate/junction box set in epoxy
    Votes: 0 0.0%
  • Other - please specify
    Votes: 7 5.6%
  • Total voters
    126
On the issue of crimping tools, I don't have anything to add for small wires.
However for larger wires and cables (e.g. battery cables) that are too large for the average crimping tool, there is a cheap and very effective way of crimping them without resorting to extortionately priced specialist tools.
I have a small anvil, (although a piece of steel plate would do), and a specially blunted cold chisel. Two good thumps with a lump hammer on the cold chisel and it's well and truly crimped.
I completely rewired my charging system and made dozens of crimps that way, and it was both effective and satisfying! Thought it was worth a mention
even the larger crimping tools which can be approx £130, can be got from the obvious internet auction site. I have found that the hydraulic crimping tools ranging from 4mm2 to 70mm2 will fit copper lugs to most battery leads satisfactory.
Sorry but I class £130 for a tool I'll use only every 5 years or so as extortionate! I bought 2 new leisure battieries for that money!
An old cold chisel, a piece of steel plate, and a lump hammer I already have - no contest
you can get them from the internet auction site for less than £130 which was my point,
for £25/60 a hydraulic crimping tool i mentioned in the post is adequate.
http://cgi.ebay.co.uk/HYDRAULIC-CRI...ls_Supplies_Electrical_ET&hash=item45f5382848
(for illustration only)
