ChattingLil
Reading past threads it seems Danboline or Blakes bilge paint is preferred options.., but what makes bilge paint bilge paint.? Can I use something readily avaialble from local DIY shop ?
High obliteration is the bilge paint formulation.Reading past threads it seems Danboline or Blakes bilge paint is preferred options.., but what makes bilge paint bilge paint.? Can I use something readily avaialble from local DIY shop ?
I'm a big fan of Danboline, or InterBilge as it is known in some countries. An extraordinarily tough paint that is easy and forgiving to apply even if you haven't managed a perfect job of cleaning the area. Tried all sorts of substitutes, including epoxy, hammerite, and garage paint, on my steel boat, but nothing that goes on as well, lasts, and is as resistant to spilled diesel and acid.
I'd like to know what sort of paint it is (enamel? polyurethane?) but International are giving away no clues.
An interesing property for something that never sees the light of day!It stands up to UV well.
Surely any of these epoxy floor paints would do the job at a fraction of the price?...
http://www.addagrip.co.uk/addaflor.html
http://www.antel-uk.co.uk/tds/waterbased-floor-paint.html
http://www.resifloor.co.uk/Floor_&_Wall_Coatings-Floor_Coatings/c20_115/index.html
I love the stuff.
Was once told by a surveyor not to use epoxy paints on the inside of a hull. His reasoning was that Danboline will allow any moisture in the laminate to pass whereas epoxy will seal it in.
