Black Sheep
I hope so, but don't forget that as a new user, he probably has to wait for a mod to approve his posts.However the big question now is - will the OP return?
Also, everyone is baying for photographs, which might take a while to organise (note to the original poster - don't worry about photos for the moment, just deal with the questions you can answer, eg is there a hole in the deck for the mast?).
If I were the OP, I might be a bit daunted by the responses here! I think a lot of the posters here assume it's a normal Bermudian setup with stayed mast, but I strongly suspect that we're dealing with something more like a Junk rig, with an unstayed keel-stepped mast.
(also, this thread was locked for a while this afternoon while the mods removed a bickering match between two members, for which I thank them, but it might have been disconcerting for the original poster if he came back while it was still locked!)
One more question for @robertfairclough6 - you described the mast as 150 x 90mm. Do you mean it has a diameter of 150mm at the bottom and 90mm at the top? You described it as "thick" - what, 10mm or so? If so, yes it'll be heavy, around 120kg, but not overly so. If it's keel stepped, and has those dimensions, then it won't need any standing rigging. Does it have any sail track on it, or is it just a smooth tapered cylinder? If smooth, then it really is sounding like an alternative rig, such as junk, but I'm sure there are other possibilities.
