There should be some letters with the amp rating.Thank you. So to carry a spare I search for the same rating and specify slow blow? (As the actor said to the marine electrician)
A sand filled fuse is often fitted when there is a potential for very high fault currents. The purpuse of the sand is to cool and stop the arc as quickly as possible when the fuse blows and to absorb the energy from the rupture. Modern types are usually enclosed in ceramic and not glass.
Although the sand also slows down the fuse a bit, it is not the same thing as a slow blow fuse.
The best advice is to see what the equipment specifies (does it mention 'HRC' anywhere?). If there is special requirement for the type of fuse, it's usually marked accordingly on the device itself near the fuse holder.
Yes you did, sort of. The thread did veer off to the 'slow blow' path right after that so I felt a little elaboration wouldn't hurt.What i said i post 3.
Putting a regular slow blow fuse where a HRC fuse is required would not be a good idea.
I'm probably not the only one to have just tried googling that out of curiosity.. google images shows a number of them so one of them at least must be a suppliers picture.Sorry for the late reply. It’s in the power supply box for a Simrad RADAR/plotter so I guess it’s likely to have bursts of high current? I don’t carry anything on board that’s like it so I need to source spares and “sand filled fuse” won’t help a google search ?
It is a HRC (High Rupturing Capacity ) Fuse. That is what you want to look for. Try Dr. Google for explanation of HRC.Sorry for the late reply. It’s in the power supply box for a Simrad RADAR/plotter so I guess it’s likely to have bursts of high current? I don’t carry anything on board that’s like it so I need to source spares and “sand filled fuse” won’t help a google search ?
I was wondering if it might have come out of a multimeter accidentally left on "amps" mode when testing voltagesI agree, but i'm struggling to think of an application for a HRC fuse on the typical motor sailor that the OP owns.
