tim_ber
Neighbour knows I can sometimes fix things...
So he has given me his extractor fan to look at. Looks new.
Electricity is getting to circuit board and leaving circuit board. Electricity applied directly to motor does nothing, so I started to look at the motor.
This component has the blue neutral wire from the circuit board going to it, but there is no continuity across the component and if I try to measure its resistance I get no result. EDIT - I HAVE NOW FOUND OUT IT IS A microtemp cutoff fuse.
http://cpc.farnell.com/thermodisc/g4a01128c/fuse-thermal-w-e-128c/dp/FF01026
How do I test it, what does it do? I'm guessing that at above 128 degrees C, it shuts the motor down. Is that right?
But, should I just buy another one and replace it? Good practice with fuses is that I should know what made it 'blow'.
Anyway,
(1)should I get continuity across it? If so then I know it has failed.
(2)Should I just replace it and test unit afterwards.
(3) Anyone know where the blue and live wire go back into choc block?! ( I usually photograph things before pulling them apart and I didn't this time. Doh!
Photos attached and writing on component appears to be : "microtemp... "
SPJABC
G4A00
T subscript F 128 C
ANOTHER EDIT: This states the fuse has blown. So, should I just replace it without looking for what blew it or try to find what blew it - some of white tape around windings look a little brown. Fan came from his bathroom.
http://www.thermodisc.com/en-US/Pro.../Microtemp®_Thermal_Fuse_Product_Bulletin.pdf
Anyway,
SPJABC
G4A00
T subscript F 128 C
