tillergirl
Today with the aid of the yard, we investigated signs of dried salt around the nut of the No 1 keel bolt. This had been replaced 5 years ago when I drew all the bolts and replaced the lot. At that time the No 1 bolt had completely failed.
Trying to undo the nut, the bolt turned very slightly before the nut released so we decided to knock it out for a look. Going underneath we prised out the bedding (Polysuphide) that we had used to seal the bolt head socket underneath and as we did so out dropped a little water. I deduce that as this water has not found its way out until we prised out the bedding, it did not get there from underneath. That leaves two possibilities: water from the bilge (well there's always a bead of moisture isn't there) had found its way under the keelson into the bolt channel or water is getting in at the keel joint.
Further evidence: the keel bolt when removed has started the wastage process. It is years from failing - perhaps 20 years - but there is noticeable wastage of a little more than a sixteenth of the radius. Also at the keel joint, despite being cleaned two weeks ago, there is evidence of very minor salt 'efferversance' showing up. On the positive side, when we did the bolts 5 years ago, there was evidence of - what shall I say - 'over wet' timber around this bolt which is now back to rock hard.
I shall replace the bolt of course as the cost of that is pretty small in the scheme of things but should I be thinking that in a future winter I should separate the keel and re-bed it. Not an easy task and one requiring a pretty major shoring of the boat so the keel can be dropped.
So the question is what is the evidence that indicates that a rebedding of the keel joint is necessary? Any views anyone?
