Moodysailor
Depending on your space / budget / etc, then there are a lot of good ideas here, and my personal preference would be to try and integrate as many of them as practically possible, because I just don't get the idea that as we are on a boat, we should struggle or "make do" and having options means you can use the most efficient/effective solution at any given time.
Passive heating is great, and can range from simple (shower bag) to complex (piped in system), the limits are only in your space, ingenuity and imagination.
Twin coil calorifier would definitely be on my list (either now or for a future upgrade). If you put in a series of change over / one-way valves you could heat the coils from main engine /genny cooling circuits, passive and diesel/propane heater depending on your need and use. The immersion would still be available
Diesel/propane water heater are the most efficient for instant/semi-instant HW.
In terms of efficiency it's not always obvious. Passive is the winner here, then it could either be diesel/propane OR engine/genny cooling water (this will depend on what you are using those for - if it's engine propulsion or genny is well loaded for other things then the cooling water is otherwise wasted heat, if you are only running the engines for HW then they are incredibly inefficient). Immersion heaters are the least efficient by a long way, but if you are on a dock with shorepower, or are running the genny anyway and have spare load to use then it makes sense in those situations.
Try to think of a way to use the existing passive or waste heat as best as possible first, after that should come heat generation - if that makes sense! You are lucky that you have quite a few options to choose from.
