lustyd
Only dive with goggles if you want to risk serious damage to your eyes. The deeper you go the less volume of air there will be in the goggles. You eyes will attempt to fill that gap.
(At 10 metres depth the volume will be reduced by 50%) I used to dive regularly with people who had prescription lenses fitted in to their masks, not cheap but they used to swear by them.
Most normal folk won't be down around 10m so this is less of a problem snorkelling than it is diving. That said, a large part of the change is in the first few metres so for comfort I would go down the mask route. Before investing in prescription mask, speak to someone who knows about such things (as opposed to someone trying to sell you stuff) because some prescriptions can actually be worse on a mask than none at all due to the nature of being in the water. I forget the details but things appear larger underwater and this allows a surprising number of the optically challenged to use a standard mask. If the trip is not for some time you may be able to try a dive with a local club to see.
