What is causing the problem with our 3.5hp Mercury 4 stroke?
I need help with the following: - I went ahead and cleaned the carburator, main jet, set screw, etc - all of it - and it starts right away at low setting, but the second I try to rev the engine, it just dies. I am able to run the engine in forward also only in the lowest setting.
I read somewhere the set screw is 1.5 turns - I have tried several things without success. I have not soake the main jet and main nozzle, but I have use plenty of carburator cleaner on it. I have not tried yet to clean the low air jet - i do not know how to paste in a message but is the one in front of the choke valve
It sounds as if you need to do a complete carb strip down and also clean and check the needle valve operation and the float height. Perhaps turn out the screw to more like 2 - 3 turns from fully in but I doubt whether that is the issue.
Richard
