It's not such an easy question to answer
In fresh water a zinc anode slowly passivates due to the formation of surface zinc hydroxide. If the boat had been in fresh water for some time before going to sea the aluminium anode would protect the prop/shaft couple.
If the boat went to sea before the film formation the zinc would protect the aluminium and probably the prop/shaft but would corrode more quickly.
Advice now is that aluminium anodes are preferred over zinc for almost all duties. The time is coming when zinc will be phased out. Unfortunately specialised anodes such as Bruntons prop anodes are not yet available in aluminium (when I last looked). I wrote an article on this subject for YM a year or two ago.
Thanks. Should have said it’s an AWB. At present there is a nearly whole zinc anode on which I will replace with an alu one so seeing if it would be worth leaving the zinc one on for as long as t lasted.
