West Coast
Noticed that the rubber seal fitted to the frame of my lewmar opening coachroof windows has come loose in places - what's the best glue to secure it back to the alloy frame?
Cheers
Cheers
Are you talking about Standard Portlights see http://www.lewmar.com/products.asp?id=8757&lid=25070
Because if you are I have the same problem on a Standard Portlight - Size 4 with the rubber seal coming unstuck in one corner and would be very interested in the solution
None needed if the tiny groove is clean, the rubber has a corresponding bit of rubber strip that fits in the groove. However! as others have said various stuff works.Noticed that the rubber seal fitted to the frame of my lewmar opening coachroof windows has come loose in places - what's the best glue to secure it back to the alloy frame?
Cheers
What size neoprene did you use? The original Lewmar seals were much wider than they were thick - about 14 by 8 at a guess. I bought and used old stock original seals without success - loss of elasticity I think.
