alec
I am in the process of putting my prop back on the shaft (bronze prop on stainless shaft).
I notice that the key needs to be replaced . It looks as though part of the key has come in contact and split .
Am I right in thinking that the taper should take the strain and not the keyway ?
If this is the case, what does the keyway actually do ?
Personally, I would much rather the prop spin if caught by a rope rather than damage the engine beds which has happened before. Unfortunately, there is no space for a rope cutter. Do I still need a key ?
Should there be a slight gap between the key and prop ?
Ant thoughts would be very welcome.
Thanks in advance.
Thanks in advance.
