rafiki_
It may also be better if all you folks who have problems with your "engineers" employed a technician instead.
+1
One "non engineer" even changed a seacock afloat with only a pint or two coming into the boatI call myself engineer.
Qualified CAA avionic design signatory, unqualified boat tinkerer.
When I did my boat thing, I was technicianing but called myself an engineer, cos I am
You can do some types of shaft seal in the water (stuffing box style - I've done it) but be prepared to get wet. And maybe a bit scared for a few minutes...
Seastoke, many thanks for emptying the bin this morning, you travelled a long way to do mine, but much appreciated
The cutlas bearing is the one on the "P" bracket, below the hull, that supports the shaft just in front of the propellor. The gland will be within the hull, and seals the prop shaft through the hull. Depending on the type and make of gland, it will either need constant checking, or periodic, but I suggest you take a picture and post on here, so folk can make a more educated stab.
is the cutlas a ball bearing type in stainless or bronze or ? i will take poto of gland goin up to boat on tuesday ,cheers
Try GOOGLEis the cutlas a ball bearing type in stainless or bronze or ? i will take poto of gland goin up to boat on tuesday ,cheers
hi omega right the boat is i colvic 36 fly twin on shafts it was re engined with tow perkins sabre 225 turbo,s it had new shafts and props ,all before i bought it so dont know what type of seal or bearing but i have no vibration off the engines .i am just trying to put a check list together when she come out in march,but is it normal to service the engines when in the water , yes i mean the boat ,
Pimp out the bow thruster!!s new pimp out pump the steering is old the steering wheels i always steer from the fly ,new bow thruster
DON`T touch anything mechanical on yer boat, unless you are a trollyes thanks for that ,ok engine cooling does it suck sea water through the sea cocks and back out of exhaust
