cygnusv
In the early summer I fitted 2 new fresh water tanks to increase our usable capacity. One of these 2 tanks is visible so I want to make it appear to be a nice mahogany (faced plywood) locker / table. The top and the sides are sorted but that leaves one visible corner. I don't want this unit to look like a box so would like the 'corner' to be rounded. The curved 90 degree bend is just under 60 cms high and I'll need to produce a 100mm radius. The bend will be a total 90 degrees with a 25mm straight at each end to attach the piece which will ideally be 12mm thick to match the rest of the hardwood faced ply.
Any thoughts about a material to use ( I can laminate to make up the thickness if necessary ) and where I can actually buy a practical material to do the job bearing in mind the 100mm radius?
Thanks in advance.
Thanks in advance.
