johnphilip
The Bukh ran fine but we were losing confidence due to its age, so we changed boats.
One thing I noticed on my friends Fulmar that now has a 25hp Beta is that with the Autoprop there's a marked tendency to squat at full power.Snooks boat having a narrower stern than a Fulmar would be even more prone to this so maybe a 20hp would be more than enough .And cheaper too.
Just to update everyone....
I went for a Beta 30 with a 2.6:1 gearbox and a 3 bladed 15x12 flexofold in the end.
Everything on the engine was in the right place for the boat,....
Everything on the engine was in the right place for the boat, the lower revs=quieter running has proved true, we can cruise at about 4.5-5 knots at lovely quiet and effortless 1700 rpm in flat water, about 5.5-6kn at around 2300. 7 knots at 3300 and the cockpit drains are full, 3600 and the back of the cockpit is under water! So I don't think I'll be using 3600 unless I have to
We also re-soundproofed when we had the chance with Noisekiller. The engine itself is much quieter and smoother. My wife and I can now have a conversation when she is sitting below in the saloon, where as before at the bottom of the companionway steps it would be a struggle to hear someone in the cockpit.
What the extra power has given me is the ability to reverse in any direction I want...With the Bukh and a 2 bladed prop I could only reverse to port, as the engine took so long to increase revs the prop walk would send the stern to port long before the boat would start moving astern and the direction could be controlled by the rudder, even then I couldn't reverse down a long marina alley without having the wind dead astern.
So while the Bukh would run continuously at a set speed, in close quarters situations it never had the speed to increase the revs fast and get the prop spinning fast quickly to be able to manoeuvre, start and stop efficiently the way the Beta 30 can.
Was it worth it? Time will tell. It's smoother, quieter, lighter and more powerful. Some of the advantage has come from the propeller for sure, but the engine has done everything I had hoped it would do and more - The "more" being the ability to reverse to starboard in a tight situation, and turn in control without the wind getting hold of me as I wait for the engine revs to increase
Ball park figure now?
Thanks very much for that ... extremely useful ... my quote was for having it all done ashore at Universal up the Hamble ... think the lifting in and out was extra to the £7k.
The apparent price advantage of a Nanni or Beta is quickly eroded by the extra costs of making it fit .
Probably because it's the easiest option. Out with the old, in with the new.
I believe the xGM series are hand-startable, but once they made the small design tweaks to turn them into xGMxx that ability was mostly lost. They still have hand-cranks but, as you say, lack the flywheel mass to make it practical. Nevertheless, every now and then I try to start my 2GM20 by hand, just to see if I can. Haven't succeeded yet
Hi all. I'm a novice at this boating game. But, I've plunged in and bought a Colvic20 motor boat with a Bukh 20 engine in it. I'm down on a tiny Greek island in a boatyard with a generator that's 60+ years old and a tiny hardware shop on the island. But wonder of wonders - we now have internet!
Does anyone know how I can fit a REV Counter to my Bukh20 engine so that I know when I'm at 2,000 revs - which is its peak performance level - i think. Thanks guys. Oh, and one more thing. Is there a Register of Marine Engines anywhere? I'd like to get into as many networks as possible. I need all the help I can get.
I did it once - fuelled by panic and desperation. Never again - after that I revised the wiring and put in an extra battery.
It's possible on GM series because they had the decompressors - but not on the YM.
Further to Snooks query, any 3 cylinder vertical engine will be smoother than a vertical twin and diesel engine design having progressed since the Bukh, all engines will, for a similar power output be lighter, quieter and probably smoother.
Rather than change the sterngear, he'd be advised to go for a very low geared gearbox and probably an engine which will produce much more power than the Bukh (modern engines rev about x 2 the Bukh but have a later peak in the torque curve).
