Carmel2
Is it time to start to thinking about changing it, or no problem?
reverse polarity wont cause dezincification but a leak to earth on a nearby boat in the marina could give you trouble. A galvanitic isolator will prevent this.
agreed, it can have many causes, its just a matter of reducing them,
a bit of thread drift; my main sheet blocks were on aluminium supports, not "connected" to anything except a grp deck, electrically the main sheet track was isolated - they dissolved, the stainless replacements I made are fine. The problem the OP has is that the prop is always in electrolyte. In another life I found that DZR material is not a guarantee that there will be no dezincification, the failure rate of DZR components was lower than brass but not by much, bronze was better but not always, often hard to know exactly what "bronze" we were buying suppliers often couldn't/wouldn't tell us, it's bronze OK! is what we got. some worked some did nt even the colour was not a consistent guide but generally the redder the better.
Bronze does not dezincify .. it does not contain zinc
Manganeses bronze contains zinc.. it is really a brass and some suppliers even call it manganese brass .. it is used for props because it is resistant to sea water corrosion but in the wrong circumstances it can dezincify.
