Adrian
A bulb has gone on the boat, there are no markings on it i have no idea what type of bulb it is to start looking for one, any ideas what it is and where to get them from?
Im sure you know but dont touch it with little pinkies when you insert the new one
There are more than one size,
G4s are 10 or 20 watt,
GY6.35 for large power 50 or 70W.
There may be others.
Take the dud one with you and measure them up.
Get Xenon if you can, last longer and run cooler.Thanks everyone, I'll get my magnify glass out ans see if its 10 or 20w
Please take care!
In my experience a 20w halogen lamp is quite unsuitable for use in a overhead down-light G4 fixture. If a previous owner has forced in a 20w lamp into your particular G4 fixture (it can be done), it will overheat and is a potential fire risk.
If you wish to replace halogen bulbs consider switching to LED replacement lamps they can save 80-90% of your precious battery power, they emit similar levels of light, run very much cooler and last at least 10 times longer than halogen bulbs.
Regards
Thanks Adrian, Ive had the boat from new so no previous owners, Ive ordered a cheapy 10w from ebay to see if its the same brightness. i did see the LED bulbs, can i use them as a straight swap or do i need a different fixture?
cheers
Adrian
