What are these?
john_morris_uk
3 Jul 2002
At sea somewhere.
I've used a similar device to alter the pitch on a variable pitch propeller on a converted Baltic trader. There was no astern gearbox so you engaged gear and then wound the propeller to a suitable f'wd or stern pitch. It made manoeuvring interesting.
Looks like the gentleman's yacht has twin props.
Rowana
Two steps lower than the ships' cat
17 Apr 2002
NE Scotland
I've seen similar wheels on an RN cutter. The prop only went one way - Ahead. To go astern, you wound the wheel which moved a couple of clam-shells behind the prop to produce astern prop wash.
Think reverse thrust on a jet engine. Same sort of principle.
Edit: look up "Kitchen Rudder"
13 Aug 2005
Bangor, County Down
Something in the back of my mind remembers "Kitchener Gear" on RN Cutters.
sarabande
6 May 2005
there were definitely Kitchener props/gear running around the Dart in the 60s, but they were on the Pinnaces, rather than the cutters IIRC. And heavy soggy jute fenders, too, much in need.
pcatterall
2 Aug 2004
Like something we had on our 1938 German 'MTB' for compressing the air tank which started ( sometimes) the engine. But they would not need to be right at the helm so suspect more to do with 'driving' as per similar suggestions.
afterpegassus
12 Mar 2009
NW scotland
Ahead and astern - one for each engine. I have seen these on older Gardeners and Kelvins before the advent of Morse type controls. Wind the wheel forwards a few turns for ahead and back for astern.
NormanS
10 Nov 2008
Yes, these are Gardner gear change controls. My previous boat had a Gardner 6L3, and that was what she had. It's simply a hand-operated gear pump, which pumps oil into a small hydraulic ram mounted on the side of the gearbox.
With a twin-screw job like that one, when manoeuvering, you needed one hand for the ship's wheel, and one for each of the gear changes, and it helped if you had another two for the speed controls.:D
prv
29 Nov 2009
Southampton
Sounds like a case for a full bridge crew, obeying the skipper's spoken orders, rather than trying to manoeuvre by hand like most of us are used to :)
"Half ahead both, starboard 20!" :)
