What are all these different greases used for?!
lyralicious
11 May 2005
Thailand. Recovering from what felt like the longe
www.patreon.com
I'm trying to help Jamie by taking care of maintenance jobs on deck and keep reading conflicting information for all the different kinds of greases out there. Please can someone tell me what the specific purpose is for the following:
Teflon grease
Silicone grease
'Marine' grease
WD40
and we also have something from Turkey called Grease Spray made by Teroson (Loctite) in a spray can... no idea what I can/can't do with that. This is a chain lube.
Are there any should do and shouldn't do rules with the above?
Jobs I'm undertaking:
Plumbing for the heads (yuk)
Servicing winches (done), brakes, blocks and furling drums
Help!
mhph
15 Feb 2007
Teflon grease
Silicone grease
'Marine' grease
WD40
Help!
The Teflon is just an additive designed to `assist` if the grease film breaks down.Silicone grease would be used if exposed to high temperatures (much higher than you would likely experience), although can be used at ambient temps.
I would expect the `marine` grease to have water resistant properties.
WD40 is just a Water Displacement material (ie WD) and can help if sprayed on various components.Not really a lubricant.
The chain lube should be what it says, designed to penetrate into links and bushes.Also should resist a certain amount of `throw off` if the chain is rotating at speed.
Hope this helps a little.Just look at operating instructions on the tin(s),should give guidance.
whipper_snapper
9 Aug 2006
Kenya
Silicone grease
Commonly smeared over electrical connections, eg back of switchboards, to prevent corrosion/damp.
.....Servicing winches (done)............
One piece of advice I was recently given by a professional is that yotties always put far too much grease on their winches and that causes problems. He reckoned virtually every call to a dodgy yotty winch was due to over greasing. The merest smear is all you need. He reckoned.
Plevier
22 Aug 2008
Brighton
Winches should use a waterproof marine grease on the bearings but keep it away from the ratchet pawls. Only use light oil on those or they will stick.
WD40 has almost no lubricating properties it's just a temporary water dispersant.
Grease spray is a solvent carried grease so you can spray it on e.g. a chain and it will penetrate as a thin liquid then set as a grease. Gets to the parts other greases cannot reach!
MoodySabre
24 Oct 2006
Bradwell and Leigh-on-Sea
Speedseal provide silicone grease for putting on the central spindle and faces of an impeller to make it easy to remove and to lubricate against the face plate.
Marine grease is presumably for the stern gland.
wklein
28 Sep 2010
Dartmouth, Devon
WD40
Teflon grease
Silicone grease
'Marine' grease
WD40
Help!
Definitely keep wd40 away from plastics as it causes certain types of nylon to expand which is the opposite of what you want.
Seajet
23 Sep 2010
West Sussex / Hants
+1, spot on; especially keep traditional grease away from winch ratchet pawls !
