Thats a diddy one , 25 ft ?
You should have no problem on your own with that . Just practice holding station and the rest is easy . The biggest problem for plastic 25fters is the wind .
Locks are easy aswell . If your going up put the bow line on if your going down put the aft line on . Both ways your boat will glide gently to the side and you can step off .
Better still, chuck a centre line on, pull it tight, and casually sort out the Bow and Stern in your own time!
Of course im rightI single hand a 25 fter every time i go out on the boat .
Ahhhhhhh.....this is a great idea......I assume I could ensure the two aft lines are set to the middle (one each side) before going out so I can access them through the sides then adjust when I moor. Then when leaving the lock, just put back to the side 'openings'.....hmmm.....must try this....
Must try ALL options that will liberate me from the chains of 'crewdom'
I will give everything a try and see what works best......
Frequently handle my 38' er single crewed. Midships line is your friend when alone - always first on and last off. Bow and stern only are no good when you're alone. Learned that first time I took current boat out by myself - windy day in lock, bow and stern only, slipped the bow on the way out, by the time I got to the back of the boat the bow had swung across the lock and crashed the anchor into the lock wall opposite. Big noise, lots of embarrassment, lockie says "why no midships line?"..... There is now!!
