vas
dear all,
following a couple of threads on grey water tanks and all the problems that forumites were facing, it was suggested that a diaphragm pump is the right one for grey water. Gulpers were high up in the list.
Sooooo, got two of them
(OK, s/h v.cheap) got spare seal set and renew them, so practically have two new pumps.
First one goes to the whale 16lt grey water tank, on initial tests wasn't overly impressed as it seemed to struggle to lift the water from the bottom of the keel to just above waterline. A whole massive 90cm!!!
various attempts, ended up mounting the whale on the side of the tank (difficult spot to access) as it's lower and not on top of the tank. Tests were a bit better. On regular use, things are quite all right. Only one washbasin linked, me washing my hands from general messy jobs I'm doing couple of times a day. However, lately I was working outside, sanding, means only dust and sea was much closer so didn't bother going up to wash up.
Anyway, today was over a week from last use and it took it around 2mins to start throwing soapy water overboard!!! Once started, all was fine smooth, noisy and quick.
Same story with the other one that's living in the e/r pumping bilge water. After renewing the seal/membrane kit it took it 3-4mins to start pumping. I had clear pipes on this one and I could see the water ever so slowly moving up the pipe. Sucking pulse was fine (imo) but i'm afraid that the two flappy seals on the body of the thing are a bit of a joke. The non return valve on the outlet is plain pathetic.
Is it me, or have others had similar problems?
I'm thinking of installing an inline non-return valve (a proper one!) in the sucking section but I'm afraid that carp may block it (especially in the bilges that are still rather filthy and full of wood chips and debris from all the work carried out...)
ah, and I doubt there's a leak on the sucking section as when it's off (and the pipe is still full of water) there's no leak anywhere
suggestions?
cheers
V.
suggestions?
cheers
V.
