girlofwight
Whale BE9003 / BE9006 Electric Field Water Sensors
Has anyone else experienced these failing repeadtly? Our heads grey water system has one, and we've now had four fail, three in situ, one doa.
My email to Whale today:
It would be helpful to know if others have had similar problems, and/or any thoughts on causes or alternatives that could go in the Whale grey tank.
We have a 2 1/2 year old motor boat, build new, by Windboats Hardy, with one of your grey water tanks installed. I can't see a part number on the grey water tank, but visually it seems to be a GWO810.
It has the AK1001b style lid with a BE9003 sensor on rods.
The vessel has 24v electrics, and the waste water system was installed at new by Hardy.
We have now got through no less than 4 of the BE9003 sensors!
Two in the first season, 2015, one survived the whole of 2016 and failed this weekend, and a new unopened spare (9006) failed out of the packet - ran continuously when immersed or dry.
I am wondering why these are so unreliable?
I have the 9003 which failed this weekend, and the 9006 (which I understand to be the same product expect for the delay) which failed out of the packet, and would like to return them to you for testing please.
I have ordered new sensors and spares directly to arrive this week.
Please can you provide a return reference, and address? Clearly depending on the results of your testing I would be looking for a refund or goodwill gesture as the failure rate is unacceptable.
I would welcome any suggestions for alternative solutions.
The vessel has a gulper pump working alongside the grey tank - we can switch the pump manually via breaker - and I believe that running dry - as opposed responding to the sensor - will not harm it.
I would recap that the use age is grey water from sink and shower only.
I look forward to hearing from you.
