yachtorion
Just wondering if I'm the only person stupid enough to use a 1/3sheet electric sander loaded with wet'n'dry paper on a well dampened (with a spray bottle, not soaked) substrate?
You will only get the odd tingle, I've done it.
Seriously it can be dangerous, if 240V an RCD or certified isolation transformer is a must, 110V tools and transformer is better.
Why would it be dangerous? How would using wet sandpaper give you a shock? What possible difference could it make?
That was the calculation I made before I did it. The tool is plastic bodied, and there are no holes in the sandpaper to allow water through into the tool. On top of which, it's going through to a generator which is a closed circuit (not earthed to ground or the boat) anyway, and there is an RCD in the line. I'm also not drenching the material - just making sure it's nice and damp.
All of which means it's very hard for me to see how I'm likely to get a shock at all, certainly beyond a momentary one across a finger which even if the RCD didn't trip shouldn't do much harm - I've been zapped that way before buy an old laser printer. IIRC it's across the chest to worry about - and it's hard to see how that would end up being a circuit..............
Yeah you are of course all correct. I think I'll buy an air compressor for next time.
Why not use Dry Cut as most of the car body shops now do, no water required and it does not clog up.
I suppose it might not do the tool much good because some moisture will inevitably get in there, but that said it is constantly blowing air through the motor and one assumes the dust path doesn't go through the motor and is well sealed from it to prevent wear.
The reason behind it is I have just never found anything anywhere near as good on gelcoat as straight forward old Wet'N'Dry used wet.
That said, I will look into the air equivalent.
