Catriem
New Member
Very interesting Anona! This means that the ratio of the MS gear coupled to the MD 2B is 1.87:1, whereas I had read 1:1. Do you think that the speed of the MS2B is the same forward and backward because if your data is correct then this could be a reason for the speed loss. Also, does anyone know if the MD2B propeller turns left or right?
Thanks for your answer
