Well I never.... did you know ?
Aja
6 Nov 2001
Cant be right. I cant see the other side of the road let alone the horizon. Bloody grat building in the way.
Donald
Rowana
Two steps lower than the ships' cat
17 Apr 2002
NE Scotland
From my schooldays -
The angle of the dangle is at right angles to the sag of the bag when the throb of the knob is a constant /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif
alant
30 May 2001
UK - Solent region
This means if your Ht of eye is 2m (I should be so lucky), the horizon is 2.0976 Nm away.
Or 2.569 Nm when @ 3m.
Since this is last one ain't much above the waterline when sitting in a cockpit, how come I can see the beach when known to be at around 4 Nm off (GPS etc position), when sailing across Poole Bay? Or is this an optical illusion.
/forums/images/graemlins/confused.gif
Beagle
20 Apr 2004
Holland
Isn't the complete calculation bewteen 2 objects on a clear and visible day something like:
2.1 *( SQRheight eyes above water + SQRheight of object)
heights: metric, result in Nm. Works great for lighthouses (or other tall objects) as well
peterb
Radlett, Herts
Square root of 2 is about 1.414. Multiply by 2.2 and you get about 3.1. And, as Beagle has said, you need to add in the horizon distance of the object you are looking at.
tugboat
1 May 2004
Devon
Re: From my schooldays -
No no Jim, the angle of dangle is inversely proportional to the sag of bag when the throb of knob is constant. Didn't they teach you anything in BP? /forums/images/graemlins/grin.gif
alant
30 May 2001
UK - Solent region
I've obviously mulitplied HoE in metres by 2.2 & then sq rooted it. /forums/images/graemlins/blush.gif
Using Tables,
2m = 2.9 Nm (3.11 using 2.2xsq rt)
& 3m HoE = 3.6Nm (3.81 using 2.2xsq rt)
2' giving 1.25Nm. (1.655 using 1.17xsq rt)
None of which seem to exactly match these multiples, unless being affected by abnormal refraction. Someone must know why.
Seafort
27 Sep 2001
Merseyside/Essex/Grenadines
Would tables not be for an average Latitude? A bit like the definition of a nautical mile.
With the TTs, charts and distance off tables, plus 2 depth sounders I muddle by... /forums/images/graemlins/grin.gif
Dave.
