Skylark
I need to make a smallish steel box section structure. I'll probably use 25x25 and 50x25, 3-4mm thickness. It will resemble a cage, about 1m x 1m x 0.5m.
Once upon a time I was quite a competent welder, both gas and electric, but I've done nothing since the late 1970s. My options are to cut the metal and take it to a local garage / fabricator or buy some equipment and do it myself. I fancy the latter..........
Does anyone have experience of using a contemporary piece of welding gear, ideally for a similar fabrication job and care to make a recommendation?
Much appreciated, thank you.
