Webasto Thermotop not starting
Falling_Penguin
23 Mar 2015
Hi all,
I’m looking for some informed guidance on a Webasto Thermo Top C / E diesel wet system (UK install).
Background / history
The previous owner removed the original Webasto control module (timer face) because he found the maximum run time irritating (around an hour).
In its place, a simple on/off switch was wired in.
With this switch fitted, the heater did previously run, and I clearly remember the fuel dosing pump clicking ~4–5 times per second during start-up, so I’m confident the switch wiring can command a start.
Current symptoms
On start command:
Combustion air fan spins up in stages (initial spin, higher speed, then winds down)
Heater body gets warm (presumably glow pin pre-heat)
Fuel metering pump does NOT click at all.
No obvious combustion (no sustained run, no exhaust smell).
The heater then aborts the start sequence.
Fuel system context
Previously, when checking the fuel supply, I found the tank standpipe / pick-up was barely passing fuel. I cleaned this out and restored fuel flow, and got the heater working again.
To eliminate the possibility of fuel starvation, I am:
...Replacing the tank standpipe
...Replacing the fuel supply line
...Replacing the inline fuel filter
Key questions / uncertainties
Control module vs lock-out
With the original Webasto control module removed, am I correct in thinking:
A simple on/off switch can start the heater, but cannot clear a fault lock-out if one has occurred?
If I buy a replacement Webasto timer/control module, would that:
Allow lock-out clearing from the module itself, or
...still require Webasto Thermo Test / diagnostics?
No pump clicking
Given that:
the heater runs fan + glow,
but the pump is completely silent,
does that point toward:
ECU suppressing pump output (soft/hard lock-out),
or an electrical issue to the pump,
rather than simple fuel restriction?
My current plan is:
Replace standpipe and fuel line/filter
Bench-test the fuel pump with a 12 V supply (for click test)
Restore a proper Webasto control module (timer)
Then look at diagnostics if needed
Does that sound sensible, or should diagnostics/control be restored before further hardware changes?
What I’m trying to avoid
Replacing parts blindly (especially the pump) if the real issue is:
control/ECU state, or
lack of a proper controller to reset faults.
Any experience-based advice from people familiar with Thermo Top C/E behaviour, especially around lock-out handling and control modules, would be much appreciated.
Thanks in advance,
Falling Penguin
I would first just give the fuel/dosing pump a direct 12V and see if it ticks and pumps fuel, which is very easy to check - I had to swap one out with our ThermoTop C as it eventually died.
You can clear some faults with a combination of turning on/off and pulling a fuse, we always had the timer unit installed though so don't know if that would also work with a basic on/off switch too.
In nearly 20 years we never had a serious fault on our ThermoTop C needing the diagnostics software - from memory I replaced one fuel pump, one burner and that was it!
Thanks Paul, that is useful. I will get down with a 12v battery and set a positive and negative to the dosing pump as you suggest. I have the new fuel line and standpipe on order, arriving within a few days and will work my way through the system. Its the fact that the timer is missing, from what I can see - that can affect the ability to reset the ECU if it has gone into a 'hard lockout'...
Thanks Pete, if I read your message correctly, you are saying that the one click will show that the solenoid is still functioning within the pump, which would in its normal use be pulsed from the ECU. ie my 'test' will produce just one audible click...at power connection...
I am very interested in how to achieve a full reset, if indeed the ECU has gone into a hard lockout condition, especially since the control unit was removed by a previous owner (replaced with a simple ON/OFF rocker switch).
Grateful to the responses so far. Many thanks.
Your symptoms are classic low supply voltage on the heavy start up load, due to low batteries or thin wiring/connections.
If the voltage falls whilst the glow plug is on the ecu does not run the pump and then shuts down the glow plug and fan, generates a fault code and if repeated locks out the heater.
Test the voltage AT THE HEATER whilst initialising. Not at the battery.
Voltage on a marine unit is less critical than a vehicle one. They have different firmware usually allowing more tollerance than the vehicle ones but Voltage is still king.
The single pump click may be subtle so you may wish to cycle the power several times in quick succession (almost simulating the ecu output).
If it's convenient you could disconnect the delivery side and check it's actually pumping.
One last thought, is there should be a small gauze on the suction side, which may get blocked from time to time. That's not relevant to not hearing the pump, but while you're at it, it's a good time to check that as a 'maintenance' item task.
Make and break the power connection to the pump, each time you do it will pulse once.
