dog
Hello all, I am hoping to draw on the collective knowledge of any heater experts. I have just finished installing a Webasto Airtop 3500, and am not quite sure what to expect from its operation. On initial start up, the heater runs to full speed and then settles down to any heat setting over 1/2. If I turn the control down below 1/2 heat, the pump ceases to operate and the heater gradually cools down to blow just cool air. I then have to put the control back up to nearly full before the unit will re-fire again. I was of the impression that it was supposed to be infinately variable from the ON position right up to full heat. (The heater is fully bled and shows no fault codes)
Do any of you experience this, or am I just trying to run the heater in hotter ambient temperatures than it will cope with (given that it is unseasonally warm)
Im sorry for the long post, but would be very grateful of some comment/reasurrance.
Thanks in advance
Brian.
Thanks in advance
Brian.
