corinthmistral
Hi there. I have a webasto HL32D. It fires up ok and runs fine (provided the batteries are completely charged). After a few minutes of running I notice a very faint mist in the cabin. I shone a torch near the heat outlets and, again, the fine mist is evident. It doesn't smell particularly of exhaust fumes, but as stated, it is really a very faint mist. I checked whether the exhaust silencer is an automotive type with the drain hole, but I can't see one anywhere obvious. The heater is mounted in an aft locker with the air inlet drawing air within the locker rather than from outside (not ideal I know). Again, the mist is evident there. Query: is there a seal inside the unit that could have broken down, thus allowing exhaust to be sucked into the clean air stream? I guess my next step is to place a pipe over the air inlet when running to ensure that only clean air can enter the unit. Any comments, advice or suggestions gratefully received. Also, can anyone recommend a good webasto engineer on the east coast (boat is at tollesbury). I believe that bob ballard is recommended - anyone had good / bad experience? Many thanks.
