webcraft
It says maximum bends 270 degrees but . . .
If you install the heater in the preferred orientation then the exhaust exits pointing straight down, so start with a 90 degree bend to bring it to horizontal.
Then take into account the fact that the gooseneck on exit through the transom will involvee a minimum 90 degree bend.
That only leaves 90 degrees for all the other bendings that might be necessary to get from the heater to the bottom of the gooseneck.
How critical is this ?
- W
- W
